Author Topic: Ultrastik 360 problem outputting to IPAC  (Read 2857 times)
genesim
  • Last login:April 12, 2010, 08:18:42 pm
« on: May 31, 2009, 01:25:05 am »
I cannot figure this out!!
I have to Ultra360's and they are both recognized fine through the USB.   The problem is that I need it to output to a key pad.
I have it going through a USB in the PCI slot.  2.0  Works fine.   Regular USB nonPCI works fine.
But here is the problem.   The wiring harness....nothing.   So I tried testing each individual post.   The only one that works is a wire coming from the Ipac regular key command to the ground.   That lights up the key???
Yet nothing else works.
Not any other combination.   Only a key command to ground.    Why would this be?   Shouldn't it be key command to key command ground to ground?   Is there a setting that makes the Ultra360 to output mode?
genesim
Re: Ultrastik 360 problem outputting to IPAC
« Reply #1 on: May 31, 2009, 02:14:04 am »
Let me ask it another way.
Ok if I want the 4 way output to Ipac do I hook up Ground or 5 Volt if I have the stick going through USB?
So far nothing is working.   Green/Yellow/Blue/Orange should be connected??? or is it possible the wiring harness is wrong?  I have never had this problem before.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #2 on: May 31, 2009, 10:29:56 am »
You need to hook up the 4 directions and ground only.
One issue might be if the I-PAC and the U360 are powered from different sources and the I-PAC is being powered up after the U360. This might happen if the USB power for the U360 is supplied by PC standby power and the I-PAC is connected to PS/2 which might be powered from main power.
Andy
genesim
« Reply #3 on: May 31, 2009, 01:18:06 pm »
Problem is solved..was a grounding issue. :cheers:
Twin-X
  • Last login:April 26, 2018, 05:59:44 pm
  • Yes this avatar was stolen too!!!
« Reply #4 on: September 20, 2009, 10:33:41 am »
Andy
Hello Andy,
I do to seem to have this problem,
When i connect my voltmeter to the harnas connected to the ipac and make a close between ground and one of the 4 colors it does not switch. If i disconnect the ps/2 cable everything works.How can i solve this issue?
Jeffry
