Author Topic: Safest Way to Remove T-Molding from Old Particle Board?  (Read 4357 times)
dgame
  • I am no Jedi
« on: May 27, 2009, 09:45:59 am »
Hi,
I have an old Atari cab that is in overall fair shape. It has laminated particle board sides.
The t-molding has the requisite cigarette burns and some rips in it and I want to replace all of it.
I am concerned about the arrowhead effect where the barbs on the t-molding might destroy the molding groove on the way out.
How do I safely remove the t-molding?
Just carefully rip it out?
Try to slide it out by the ends?
Try something else?
Thanks.
SirPeale
  • Green Mountain Man
Re: Safest Way to Remove T-Molding from Old Particle Board?
« Reply #1 on: May 27, 2009, 09:56:51 am »
You'll never slide it out.  The only way it to lift it out.
If the wood is too damaged after you remove it you can fix it with Bondo and reroute.
« Reply #2 on: May 27, 2009, 11:50:20 am »
Could you reroute it with the slot cutter (ie cut right through the old tmold), or would that be too dangerous?
Just wondering really...
« Reply #3 on: May 27, 2009, 12:43:51 pm »
If the particle board is so degraded that the T molding is going to rip off chunks you are going to have to fix that before putting in new molding anyway.
channelmaniac
  • Last login:May 11, 2019, 12:36:18 am
    • Arcadecomponents.com
« Reply #4 on: May 27, 2009, 05:40:42 pm »
Heat gun or a hot hair dryer.
Heat up the t-molding and it will be more pliable. Also, if it's glued in it'll help soften the glue.
Just be careful not to damage any art, paint, or Formica on the sizes.
Call me a cheap bastard... I learned to fix things to save money... even surface mount soldering...
Visit my website: http://www.arcadecomponents.com
My repair logs are kept at: http://newlifegames.net/nlg/index.php?board=19.0
SavannahLion
« Reply #5 on: May 27, 2009, 11:30:01 pm »
+1
Besides, if the T-Molding is that old, there's a good chance it'll just pop right out. My Sega cab's T-molding is literally slipping right out of the cab because the barbs are so compressed they can't keep any tension any longer.
dgame
  • I am no Jedi
« Reply #6 on: May 29, 2009, 11:55:58 am »
Thanks Everyone,
I'll just be gentle and see what happens.
