Author Topic: Hantarex Polo Star 28 transistor keep blowing up.  (Read 3787 times)
Deathadderpt
  • Last login:July 15, 2009, 04:55:14 pm
« on: May 26, 2009, 12:17:54 pm »
Hi guys
I have a problem with an HANTAREX POLO STAR 28. When i turn the monitor on a transistor keep blowing up. when this happens i star to hear a click every second. I already change the line transformer and it continues to blew. I give a photo of an chassis similar to mine and the transistor is mark with a red line. Its on the right side.  If anyone can help me.
« Last Edit: May 26, 2009, 12:42:57 pm by Deathadderpt »
grantspain
Re: Hantarex Polo Star 28 transistor keep blowing up.
« Reply #1 on: May 26, 2009, 01:18:46 pm »
i had this happen a few times,the first time my replacement phillips transistors were part of a  bad batch(bu2527) and the second time there was a few electrolitics in the psu section causing the transistor to blow
there is also a high voltage cap on the collector of the hot which will do the same
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #2 on: May 26, 2009, 10:15:53 pm »
if ur frequently losing the hot , check for cold solder joints on ALL flyback pins, driver xformer, deflection circuitry .
also check for excessive B+ voltage
there is usually a 'lytic bypass cap (1-10uF/160-250v) on the b+  side on the driver xformer.
when this cap degrades, the drive waveform becomes distorted .
this distortion affects the duty cycle of the horiz output xistor (hot).   typical pulsewidth 12.6 us @ 15.750 khz
as the xistor stays on longer over time, eventually stress will cause the xistor to short.
qrz
