Author Topic: WG 19v1001 distorted image  (Read 1627 times)
Paul Olson
    • Paul's Arcade
« on: May 23, 2009, 02:16:56 pm »
Any idea what would cause this distorted image? I am assuming it is a yoke alignment problem, but I really don't know anything about that. This monitor also has a questionable vertical circuit. I had a vertical line in the center, and couldn't find the problem; all of the transistors in the circuit tested OK. One day it magically fixed itself, and the picture shows what came up then. Any ideas?
Thanks,
Paul
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: WG 19v1001 distorted image
« Reply #1 on: May 23, 2009, 11:08:19 pm »
vert position and linearity is off a bit .
position may be an adjustment . linearity will likely be a 'lytic cap that is changing value (in vertical circuitry) .
sudden performance changes that "magically fixed itself" can be loose connections on pcb.
time for a visual inspection of the pcb , and resolder anything that looks questionable....
qrz
