Author Topic: medium res tube queastion  (Read 3698 times)
ZMB
  • Last login:May 14, 2010, 07:46:29 pm
« on: May 22, 2009, 05:50:13 pm »
I have a neotec nt-2501 monitor that was in a crusin. The High voltage section burned a hole right through the the chasis board. Can I still use the tube with other chasis boards?...like a wells standard res?
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: medium res tube queastion
« Reply #1 on: May 22, 2009, 11:00:20 pm »
it shouldn't be a problem.
Kevin Mullins
    • Me on Myspace
« Reply #2 on: May 23, 2009, 01:28:15 am »
and as long as you have the proper yoke to go with the chassis you choose.
qrz
« Reply #3 on: May 23, 2009, 11:16:14 pm »
actually , on the low/med wg's , the yokes are standard zenith tv yokes ( 15khz )  nothing special
they change capacitance via the jumper for each scan frequency.
same scheme is used in multisync crt computer monitors.
capacitance switched in/out via mosfets or relays to make it easier.
qrz
Kevin Mullins
    • Me on Myspace
« Reply #4 on: May 24, 2009, 08:36:30 pm »
That's actually good to know, which obviously I didn't.
I've had a couple 25" medium resolution tubes laying around (meaning medium res yokes) that I wanted to do something with. I may just make them std res and be done with it since I use more of those anyways.
But the OP did mention they have a Neotec tube, so will this still apply if they go with say a WG std res chassis ?
qrz
« Reply #5 on: May 24, 2009, 10:13:18 pm »
probably .
awhile back , i got LAZY on a crt swap on a wg chassis . i don't recall the donor tv brand, but i left the
yoke/conv rings where they were.
 swap worked fine . just had to modify the yoke connectors to mate w/chassis.
of course, your results may vary  ;D
qrz
