Author Topic: Cleaning artwork before vectorization?  (Read 1666 times)
fatfingers
  • Got UltraStiks?™
« on: May 22, 2009, 04:22:54 pm »
What does it mean when someone says they have 'cleaned the artwork so now it is available for vectorization'?
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
Trebeck
  • "The Arcade" - Build #4
Re: Cleaning artwork before vectorization?
« Reply #1 on: May 26, 2009, 03:54:24 pm »
I could be wrong but it sounds like they actually clean the printed artwork for high dpi scanning then maybe some color correction.  If there are chunks missing you can sometimes clone other sections especially in patterns.  Some people use a function in Illustrator called Live Trace that traces photos/scans (raster) into curved art (Vector) which I do not recommend.  But in order to do it properly your scan has to be as clean as possible.
It's just the cleaning process you should do before tracing.  Makes life easier.
Hope this helps ya.
fatfingers
  • Got UltraStiks?™
« Reply #2 on: May 26, 2009, 04:09:15 pm »
Thanks.  So basically it's just prepping the work for the cleanest scan available, and then any touchups on the digital scan before the tracing begins.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
