Author Topic: Need Help with Spinner and Trackball  (Read 1352 times)
genesim
  • Last login:April 12, 2010, 08:18:42 pm
« on: May 22, 2009, 03:00:58 pm »
I have searched the archives, but I admit that I don't really know how to search specifically for this problem.    I am getting tired and I don't seem to be able to get the answer at this time.
Plus I have never had this happen.
Spinner (Spintrak) only goes in Y direction(up/down)  Happs trackball only goes in X Direction(left/right).
I am running in Windows XP.   Is there an option that you can either make each totally independent of each other?   Or at the least they duplicate the movement?
Well I know it can, but I can't remember how.   Only thing I can figure is some mouse drivers that I installed mucked it up.   Any help is great appreciated.
Ginsu Victim
  • Comanche, OK -- USA
Re: Need Help with Spinner and Trackball
« Reply #1 on: May 22, 2009, 03:03:18 pm »
USB or PS/2?
All the time, or just in MAME?
« Reply #2 on: May 22, 2009, 03:45:10 pm »
I had this happen and it ended up that I was trying to drive too much on the usb port they were connected to.
Once I got a good powered USB hub, everything started working fine.
genesim
« Reply #3 on: May 22, 2009, 07:34:16 pm »
No one is going to PS/2 and one is USB.   This one baffles me.    Still, can't hurt to at least try the USB port going through the PCI slots, that is how I had it before.
genesim
« Reply #4 on: May 23, 2009, 05:26:10 am »
Figured it out!!
Two problems.
The Spintrak had a jumper issue.   I lost it.  ;D  If it ever had one.   At any rate I put one on, and I guess it makes it a slave..or enables the other coordinate(x-axis instead of y).
Second problem..Happs trackball worked best in USB.   While the above seemed to fix the movement after plugging it into a PCI USB I got much better results.
Both work fine now.
Ummon
  • Trade Count: (+13)
« Reply #5 on: May 25, 2009, 05:03:12 pm »
Oh. Good. Put 'solved' in the beginning of the header.
Yo. Chocolate.
Stephen Hawking
