Author Topic: Routing on thinner plywood  (Read 3041 times)
Nakune
  • Last login:June 07, 2009, 10:58:18 pm
« on: May 21, 2009, 12:04:10 pm »
I'm planning on building an arcade stick for the 360, but have come across a question regarding the materials I was planning on using. I was going to use 1/4" plywood for the top panel, but am concerned about mounting the joystick. I have read that the stick should be mounted about 1/4" below the surface, and this brings me to the question of whether or not routing is necessary, or whether I should just get a thicker piece of plywood. I was planning on the overall depth of the box to be about 2 1/8", so I should have some room if need be. This is my first project with little woodworking experience, so a dumbed down answer would be nice  :)
Chadwick
  • Last login:January 11, 2010, 03:23:34 pm
Re: Routing on thinner plywood
« Reply #1 on: May 21, 2009, 12:18:48 pm »
With mats that thin I would just bottom mount and skip routing.
« Reply #2 on: May 25, 2009, 02:37:58 pm »
How wide is the panel?  If that panel has any width at all 1/4" ply might flex in a rough game.
massive88
« Reply #3 on: May 27, 2009, 11:00:40 am »
Ideal mounting for Sanwa sticks is 3/8" below the surface.
Dont route out anything, 1/4" ply + 1/8" plexi is perfect.
If you are worried about flexing, put in a stiffener bar or additional supports, or both like I did on my first stick:
8 Supports instead of the more traditional 4 corner supports:
Glued bar to center of the panel for additional stiffness:
