Author Topic: Isolation Transformer Wiring - Quick ?'s  (Read 2096 times)
tommyinajar
  • Last login:November 15, 2023, 12:23:20 pm
  • My other cab is a Cube Quest
« on: May 19, 2009, 05:49:37 pm »
I've got a used Isolation transformer I wanted to use to power a monitor- it had a plug already soldered to one side for 120V but the other side  (output) has no markings- and the wires are the  same color - Does it matter at all which of the pair I hook up to the black and to the white wire of the monitor ? Thanks.
SirPeale
  • Green Mountain Man
Re: Isolation Transformer Wiring - Quick ?'s
« Reply #1 on: May 19, 2009, 09:33:10 pm »
It should not.
Kevin Mullins
    • Me on Myspace
« Reply #2 on: May 19, 2009, 09:51:47 pm »
Ditto .....
It's AC, therefore it doesn't make a difference.
tommyinajar
« Reply #3 on: May 20, 2009, 12:55:10 am »
I just wanted to double check- Thanks,
