Author Topic: Mala doesn't display Marquee for Other Emulator  (Read 2824 times)
daok
  • Last login:July 04, 2009, 09:30:00 pm
« on: May 19, 2009, 01:32:34 pm »
Hi,
I have all marquee for the Mame Arcade games. I have a list of N64 games and I have in the menu (right button>Options>Other emu config) added the emulator (I see games in the list) and I have added a directory for the Marquee. When I am in Mala, I can see all games and play but I do not see the marquee images.
The directory with the marquee contain for exameple Mario Kart 64 (E) (V1.0) [!].png for the game Mario Kart 64 (E) (V1.0) [!].z64.
What am I doing wrong?
csa3d
  • Will game for food
    • Galaxian Mame Conversion
Re: Mala doesn't display Marquee for Other Emulator
« Reply #1 on: May 19, 2009, 01:43:10 pm »
What happens if you remove the spaces out of the rom name and the marquee image (just as a test).  Are there any options to encapsulate the image path in quotes?
I suspect since mame doesn't use spaces in it's name, it doesn't have this issue.  However, I've never attempted to do this so I'm only guessing.
-csa
daok
« Reply #2 on: May 19, 2009, 01:59:00 pm »
Thanks csa3d,
You got it, the space was the problem. Now everything work fine :)
Thank you :)
csa3d
« Reply #3 on: May 19, 2009, 11:37:22 pm »
So your solution was to rename all your roms, or was there a encapsulate function?  If it's a rename rom issue, then maybe loadman can add it to his bug list for things to do on a lower priority of course ;)
-csa
