April 06, 2026, 02:33:53 pm
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon
through our link. Thank you!
In 2027, BYOAC hits 30 years old.
It started in 1997
. It has cost saint somewhere between $25,000-$30,000 to host in its lifespan.
Main
Main Forum
Power supply
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Power supply (Read 1445 times)
crashdmj
Trade Count:
0
Full Member
Offline
Last login:August 26, 2003, 08:55:42 pm
Hulk smash!
Power supply
on:
July 03, 2003, 11:47:53 pm »
If I plan to wire coin door lights (4), P360 (4), a marquee and i dunno some other stuff; what is the best kind of power supply I can get (or most reasonable). Oh by the way its for a computer too.
Derek
Logged
BobA
Trade Count:
+14
Full Member
Offline
Last login:July 11, 2018, 09:52:14 pm
What Me Worry?
Re:Power supply
Reply #1 on:
July 04, 2003, 10:04:22 am »
If it is to power your PC get a good quality ATX supply that will properly connect to your PC motherboard. It should be either AMD or P4 certified depending on your choice. Get one of at least 350W and you should be OK powering additional non computer items such as the 360 sticks. If you use high output LEDs for your coin lights you will greatly reduce their power usage. DO NOT power your marquee from the PC PS. Use a 120V flourescent light.
Regarding other stuff, don't try to power a automotive stereo amp from the 12V of your PC supply. It takes too much power. Get a separate supply if doing the automotive stereo route.
Remember most PC problems are due to cheap power supplies. Do not get a cheapy.
BobA
Last Edit: July 04, 2003, 10:06:13 am by BobA
Logged
crashdmj
Trade Count:
0
Full Member
Offline
Hulk smash!
Re:Power supply
Reply #2 on:
July 04, 2003, 12:24:24 pm »
How should I power the marquee, should I get a power strip and keep it inside the cab?
Derek
Logged
Pyronious
Trade Count:
0
Full Member
Offline
Last login:June 04, 2021, 09:52:25 pm
Klatuu... Verata... Necktie.
Re:Power supply
Reply #3 on:
July 04, 2003, 01:13:57 pm »
I recommend getting a power supply that has a "switched accessory outlet" on it. You can plug your powerstrip into that, then the monitor and marquee into the powerstrip. It will automatically turn on and off when the computer is turned on and off.
For example:
http://vantecusa.com/van420.html
P.
Logged
BobA
Trade Count:
+14
Full Member
Offline
What Me Worry?
Re:Power supply
Reply #4 on:
July 04, 2003, 01:21:43 pm »
Pyronius
Great Power Supply! Solves the switched AC problem for peripherals that has had everyone making relay hacks or buying switched outlets from Sears.
BobA
Logged
grafixmonkey
Trade Count:
0
Full Member
Offline
Last login:October 16, 2010, 08:16:50 pm
must... tear self... away from... Tron...
Re:Power supply
Reply #5 on:
July 05, 2003, 07:49:33 pm »
but.... we like building crazy electric hacks.... right?
Logged
-- See my grafix, circuits and cab on my
-- new arcadey page:
http://www.bkgrafix.net
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Main Forum
Power supply
