Author Topic: Easier way to configure prefered resolutions for every game? Shared .ini?  (Read 2198 times)
tyson171
  • Last login:December 07, 2022, 09:34:22 pm
Hey everyone, putting the finishing touches on my mame cab, getting ready to start configuring hyperspin/mame.  Is there a way to get a close/preset resolution (that works) for every game, and then adjust the resolutions from there?  Or does anyone have their list of .ini files uploaded anywhere?  I don't want to go through and manually set up every single resolutions for every game, I'm using an wg 25" monitor with soft 15Hz (amd chipset).  If this isn't uploaded somewhere, i'll just have to go through and set up everyone myself, then i'll share my files.  I think we should get a master list of preset resolutions, then each user can configure the resolutions if the needed to be changed for there setup (or maybe this is already done?).  Also is there a site that has the resolutions that each game natively ran at?  Thanks for your time...just looking for some direction....... :)
BASS!
  • Just have fun.
There are several tools along with full walkthroughs in the wiki. Spend some time in there, and it will answer questions you didn't even know you were having in the first place.
northerngames
  • Trade Count: (+18)
AVRES TOOL for correct res display
mame32FX to balance the sounds out
quikres tool for desktop res setting
mamewah for frontend
« Last Edit: May 14, 2009, 05:22:48 pm by northerngames »
BlazzingFlippers
  • Last login:November 26, 2015, 04:34:09 pm
Where can I find the AVRES tool?  I can't seem to find it anywhere for download.  Is this something that only comes with the ArcadeVGA card?
ssndk
  • Last login:January 22, 2010, 05:59:03 pm
http://ultimarc.com/avres.zip
BlazzingFlippers
Thank you!   :cheers:
