Author Topic: 5 volt source?  (Read 1473 times)
T_brez
  • Last login:July 03, 2009, 02:59:33 pm
5 volt source?
« on: May 12, 2009, 12:18:53 am »
Based on your experiences, what is the easiest method for obtaining a 5 volt source for various applications on your cab?  ???
severdhed
  • RIP Dinosaur Hippo
Re: 5 volt source?
« Reply #1 on: May 12, 2009, 12:30:55 am »
assuming this is a PC based cabinet, the Red wire from your PC power supply is a good source of 5v.  this is easy to tap into from any of the hard drive/floppy drive power connectors.  that is what i used to power my Utrak LEDs, as well as my novagem buttons.
T_brez
Re: 5 volt source?
« Reply #2 on: May 12, 2009, 12:33:26 am »
I know you run the risk of drawing too much current if you try to tap the usb ports. My machine will be possess a hefty amount of LEDs, does tapping the pc's 5 volt line carry an equal risk, or by chance if there's a different limit do you know around what it is? BTW, i'm waiting on electric ice-t buttons from GGG right now, but how do you like your nova gem buttons?? :D
DJ_Izumi
  • Last login:November 04, 2023, 04:19:22 pm
Re: 5 volt source?
« Reply #3 on: May 12, 2009, 02:41:26 am »
A single power line on USB 2.0 if I recall correctly can only carry 500mA at 5v, that's a whopping 2.5 watts.
That's not a lot of power.
You could easily tap the 5v line off a molex connector off the PC's CPU and get a lot more amps.  The total amperage depending on PSU to PSU, however if you're powering LEDs it'd likely be more than enough.
Blanka
Re: 5 volt source?
« Reply #4 on: May 12, 2009, 03:21:46 am »
This is a separate supply for arcades with 15 amps on the 5V:
It also has 12V 4 amps for a nice stereo amp.
