Author Topic: 60 in 1 screen orientation question  (Read 1244 times)
tophatne1
  • Last login:January 09, 2016, 12:05:15 am
« on: May 11, 2009, 11:56:05 am »
I just got a 60 in 1 no links to copyright violations please --- saint and plugged it into my jamma cab to test it out.
The menu and screen is upside down.
This should be easily adjusted once I get into set up mode correct? It's just on the default factory setting right now.
The reason why I'm asking is because it'll be a few days before I have a way to get into the set-up menu to adjust anything. In the manual it says you can turn on/off screen flip but I'm thinking that's for cocktails. I'm using an old Pac upright.
« Last Edit: May 11, 2009, 12:13:03 pm by saint »
FrizzleFried
    • Idaho Garagecade
Re: 60 in 1 screen orientation question
« Reply #1 on: May 11, 2009, 12:10:32 pm »
There is a dip switch setting on the board to flip the screen.
tophatne1
« Reply #2 on: May 11, 2009, 12:21:42 pm »
thank you sir.
