Author Topic: Newbie intro and question  (Read 2723 times)
Masselectric
  • Last login:October 30, 2009, 01:07:51 pm
« on: May 07, 2009, 06:41:09 am »
Hello All,
First post , I'd like to thank all for such a great place to get information , I was able to convert a dead Frenzy/Berzerk to Mame for my brother in law using the information found here , I also saved all the original hardware so it can be restored
it was made with 2 player fighter style CP using ipac and Mala and Happ supers (no pics)
My question is on my second build
I think I am missing something simple
I am trying to use two flight sticks , one USB and one on the gameport
When I use commandline with -joystick the flightsticks work , but when launched from Mala it is only seeing the keyboard , I tried clicking and unclicking joystick and mouse under options/controllers but this only seems to affect Mala and enables joystick scrolling for games
where can I have Mala pass on - joystick to Mame ?
Thanks Again
Randy
loadman
  • Moderator
  • Last login:Today at 07:54:21 am
  • MaLa FE developer
    • MaLa
Re: Newbie intro and question
« Reply #1 on: May 07, 2009, 06:42:19 am »
mame config is set in mame.ini
Masselectric
« Reply #2 on: May 07, 2009, 07:05:31 am »
I'll check it
My confusion was because when I connected the ipac , the happs just worked
I'll try to keep the Newbie questions to a minimum and read more
Randy
loadman
  • Moderator
  • MaLa FE developer
    • MaLa
« Reply #3 on: May 07, 2009, 07:11:27 am »
You can use the built in mamee.ini editor built into mala. That covers 90% of it.
options - mame - basics (config) Button
Masselectric
« Reply #4 on: May 07, 2009, 03:54:07 pm »
That worked , I modified joystick from 0 to 1 in the mame.ini
I see where you were talking about changing it in Mala but will need to play around more to figure it out
Randy
