Author Topic: Quick Question about Serial PC Peripherals...  (Read 1177 times)
slapaham
  • Last login:January 31, 2012, 05:32:32 pm
« on: May 04, 2009, 08:20:07 am »
I'm getting a Supergun with Neo Geo joystick ports. These are 15pin but female. I have 2 PC peripherals that have 15 pin (serial) but are male... if I purchase a gender changer (if there is one) will these work on the Supergun?
Cheers! :cheers:
BobA
  • What Me Worry?
Re: Quick Question about Serial PC Peripherals...
« Reply #1 on: May 04, 2009, 09:13:35 am »
It depends on what you are attaching. Supergun ports are not really serial they just use a serial connector.  So if the PC peripheral is serial it will not work if it is a compatible gamepad for superguns such as a neogeo gamepad it will work.   Only a very few console type gamepads like the neogeo or ones wired specifically for superguns will work.
« Last Edit: May 04, 2009, 09:17:50 am by BobA »
slapaham
« Reply #2 on: May 04, 2009, 10:01:32 am »
Ah, okay, cheers Bob! I thought that would probably be the answer!
It's not a problem as I have AES sticks anyway, just thought it could interesting trying to get a Yoke or Steering wheel to work - probably a bit too ambitious though, I think! ;D
