Author Topic: MAME erases cfg (back to default)  (Read 1898 times)
joemama
  • Last login:June 06, 2011, 04:11:36 pm
« on: May 03, 2009, 08:17:27 pm »
Mame cmd line version with Quickplay as a frontend.
Xbox 360 wireless
Controller not powered on and start MAME. (Input cfg is set at n/a)
Turn on controller and restart MAME. (Input cfg back to default)
I could set the cfg to read-only but wondering if there is any other way from having MAME setting my cfg to default?
mr_doles
  • Last login:November 25, 2025, 08:42:10 am
  • nuff said
Re: MAME erases cfg (back to default)
« Reply #1 on: May 04, 2009, 12:33:55 pm »
Now I may be reading what you are asking completely wrong but I would use the ctrlr file.  There is a tutorial in the wiki here that explains how to use it.
This is from the above link:
Mame rewrites the cfg files every time mame is run, while the ctrlr is not changed by mame ever
joemama
« Reply #2 on: May 04, 2009, 08:12:01 pm »
Thx for the link, I'll look into it.
Edit: worked perfectly, thank you again.
« Last Edit: May 04, 2009, 09:08:00 pm by joemama »
