Author Topic: Can I adjust mame volume with hotkeys in Mala?  (Read 5641 times)
AE35
  • Last login:January 18, 2022, 01:48:24 pm
  • That sure is a nice raygun!
« on: May 03, 2009, 03:56:55 pm »
Hey!
I would like to have up/down volume bottons on the back of my cabinet..
So, can I do this from Mala? All I need is two bottons, one up one down. I don't use
any GUI sounds or BG music.
Nicholas
dungbeetle46
  • Last login:June 25, 2016, 07:27:47 pm
Re: Can I adjust mame volume with hotkeys in Mala?
« Reply #1 on: May 04, 2009, 04:17:53 am »
right click to get to options in Mala goto
controller
keyboard
advanced
and here you can set the buttons to adjust volume
cheers
AE35
« Reply #2 on: May 04, 2009, 10:21:00 am »
But it doesn't seem to work... ???
Nothing happens...I just mapped the up and down to two keyboard buttons
dungbeetle46
« Reply #3 on: May 04, 2009, 10:34:24 pm »
it will only adjust the volume while you are in the menu, not while in a game
and under sounds and music
options
put a tick in display volume on change, this will show the volume level when changing it.
cheers
if your using mame you can press tab while in game choose slider options and change the master volume with joystick left or right
« Last Edit: May 04, 2009, 10:40:08 pm by dungbeetle46 »
AE35
« Reply #4 on: May 05, 2009, 04:12:38 am »
Ok....I need to do it while in a game, so I just downloaded cabvol...that seems to work
(with only two buttons, one for up and one for down)
