Author Topic: stupid question, but i have to ask  (Read 2743 times)
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
« on: July 02, 2003, 07:51:49 pm »
im a newbie of course, but im getting ready to build my first cp, and i know how big the holes are for the buttons, but is it the same for the joysticks?  1-1/8"??  i just want to make sure!  and all buttons are the same correct?....oh and my joysticks are super 8's from happ.
J_K_M_A_N
Re:stupid question, but i have to ask
« Reply #1 on: July 02, 2003, 08:12:02 pm »
That is what I used. Good luck.
J_K_M_A_N
jhsmith321
  • Last login:December 26, 2007, 09:45:27 am
  • I dig the skin I
« Reply #2 on: July 02, 2003, 09:23:04 pm »
That was the mesurement that I used too!
hulkster
« Reply #3 on: July 02, 2003, 10:14:45 pm »
well i just looked at the post about "shaft not being long enough" (heh) and it showed at the bottom, a dude having a big square cut out of his cp.  thats what i was wondering.  see i dont have my parts yet, but im going to build the cp and then put the parts in when they arrive.  but it looks like on that dudes cp that he cut a big square in his cp as apposed to a 1-1/8" hole for the joystick like i mentioned earlier.  now im confused!!!!  tell me yes or no, can i just use a 1-1/8 hole saw for drilling on my cp if all im putting in are buttons and super8 joysticks???
grafixmonkey
  • Last login:October 16, 2010, 08:16:50 pm
  • must... tear self... away from... Tron...
    • My graphics/arcade/circuits site!
« Reply #4 on: July 02, 2003, 10:27:19 pm »
That's me...  I used Happ joysticks, and they all had a 2.5" square measurement on that box that sticks through the panel (the square hole).  To get it to sit flush I had to use a router to shave a border off the top of the hole, which wasn't hard at all but you might not have one.
Some people mount those to the bottom, and let the joystick stick through.  I dunno which is better, this is the first time I've done this too.
-- See my grafix, circuits and cab on my
-- new arcadey page:  http://www.bkgrafix.net
hulkster
« Reply #5 on: July 02, 2003, 11:56:59 pm »
okay, well for personal pref. i would rather mount the joystick box underneath the cp and have the stick itself up above the cp.  how thick should the mdf be then?  i also want to put some contact paper/design as well as some lexan over the top.  so with all this taken into account, how thick should the mdf be?  i already read the post below that talked about this sorta, but it involved routing.  anyway, can someone help me with my question?
madk
  • Last login:March 28, 2017, 04:59:49 pm
  • I actually am a llama!!
    • Digital Something
« Reply #6 on: July 03, 2003, 12:00:30 am »
My sticks are mounted on the bottoms of my 1/2 inch mdf.  On top of the wood I even have 1/4 inch lexan and I still have plenty of room.
Matt (mad-k)
hulkster
« Reply #7 on: July 03, 2003, 12:12:39 am »
okay, thanks man.  i think ill go with that,  unless anyone else can contradict it
hulkster
« Reply #8 on: July 03, 2003, 12:45:50 am »
well i have another question, along with my super8's, i also got a 4 way joystick from happ.  however, i was reading something about people having to buy a mounting plate???  huh?  why wont the 4 way work the same way as the super8?  all i have to do for the super8 is drill a hole and mount from the bottom, is the 4 way not the same?
AlanS17
    • AlanS17
« Reply #9 on: July 03, 2003, 01:15:53 am »
If you're talking about the Ms Pacman replacement 4-way then you're talking a totally different joystick. It has a MUCH shorter shaft since it is specifically made for the new Ms Pacman/Galaga machines which have a short stick and a short "throw". This means it has to be mounted right at the surface to get the proper placement. That means you need a plate or you have to flush mount it into the top of the panel.
hulkster
« Reply #10 on: July 03, 2003, 01:26:05 am »
hmm, well i cant remember exactly what kind of 4 way i ordered.  but i DO remember, that ordered extra super8 joysticks, and i know that they are 4-8 way switchable.  im not a perfectionist, so i dont need the best possible control, but if i switch the control to a 4 way on the super8, will it be okay?
AlanS17
    • AlanS17
« Reply #11 on: July 03, 2003, 01:42:33 am »
Well I tried it and I didn't like it. It's supposed to keep it from registering the diagonals, but the thing still moved in a circle. Ontop of that, mine really didn't work and I kept hitting the diagonals anyways... Maybe you'll have better luck.
meta87
  • Last login:September 30, 2004, 07:36:28 pm
  • Dont Mess with Texas
« Reply #12 on: July 03, 2003, 03:49:39 am »
From what I've heard, it should still go in a complete circle, but the diagonals won't register while your playing.
Happy_Dude
  • Last login:June 30, 2003, 09:26:03 am
  • I'm a Damn fool !
« Reply #13 on: July 03, 2003, 04:37:46 am »
Couldn't you just hook the diagonals up to a on/off switch ? seems like the simplist solution :)
paigeoliver
  • Awesome face!
« Reply #14 on: July 03, 2003, 05:21:15 am »
There are not separate switches for the diagonals. A diagonal is when it activates two switches at once. Thus no on/off switch is possible.
Also, unless the stick's movement pattern is diamond shaped, then it will feel wrong for 4-way games (which is the problem with most 4-way/8way sticks).
hulkster
« Reply #15 on: July 03, 2003, 10:03:58 am »
so i guess ill have to order a mounting plate from oscar right?  will that fix it?
