Author Topic: JPAC wiring woes?  (Read 1536 times)
cheesewood
  • Newbie
  • Last login:April 27, 2009, 06:04:33 pm
JPAC wiring woes?
« on: April 27, 2009, 11:39:56 am »
Hey gang,
I (not so) recently purchased a JPAC to hook my arcade cab up to my PC.  After a handful of issues here and there, and a whole lot of research, trial and error, I managed to get everything hooked up and reading inputs correctly.
Now for some reason, all the joysticks/buttons work and it's semi-playable, but the mapping is all wonky.  Stuff like the input I have mapped to 1P Joystick up ends up getting mapped to 2P right, 2P button 6 is mapped to 1P start (and ends up being the shift button no less), and all kinds of funkiness like that.
I spoke to Andy at Ultimarc and he's been walking me through this stuff and has been an ENORMOUS help, and he linked me to the test/program mode faq and I'll be trying that when I get home tonight.
However he mentioned that it may be a wiring issue as well, and I'm wondering if I'm missing something - the joystick and buttons 1,2,3 for both sides are connected to the JAMMA harness, which worked fine when connected to the CPS2 board that was inside.  Buttons 4,5,6 and the grounds for them on both sides I've wired directly into the JPAC.
I was wondering if anyone knew off the top of their heads what could cause the mapping/programming to go all crazy like that?
swamprat96
  • Last login:January 10, 2012, 03:29:46 pm
Re: JPAC wiring woes?
« Reply #1 on: April 27, 2009, 07:08:20 pm »
Test mode is the way to go. Use the direct keyboard method (you'll need a PS2 keyboard) and enter control-Alt-P together. Press L and it will list the assignments. If they are correct its a wiring issue. If they are way out press R to reset them and e to save and exit. Now start again and relist the assignments - they should now be ok
I'm guessing its either a wiring issue such as a shorted wire or the J-Pac needs reprogramming. I use the test mode often to check faults
BTW- the J-Pac should show any stuck buttons (read shorted ) when you fire up the test mode. Look to those first and just dissconnect them as a start then test again.
The test mode is simply brilliant- you picked a great encoder. Andy's products rock
