Author Topic: Turning on Elo OSD menu to turn brightness up ?  (Read 2495 times)
tteettuk
  • Last login:December 28, 2011, 08:24:02 am
« on: April 25, 2009, 06:56:44 pm »
Hi I have a Elo 17 inch touch screen and want to adjust the brightness how do you get into the menu >? I have got into the setting up menu adjusting the touch part but where is the brightness etc ?
BobA
  • What Me Worry?
Re: Turning on Elo OSD menu to turn brightness up ?
« Reply #1 on: April 26, 2009, 08:46:20 am »
Any elo I have used has had buttons on it to access the setup menu.   Some have a menu button but on one you had to touch the power button.  Holding the power button down turned the screen on and off but just a small push brought up the setup menu.
tteettuk
« Reply #2 on: April 26, 2009, 11:24:26 am »
Hi it has a small button at the back, but if you press it it just turns the screen of, no menu, I belive there is a remote corded set up option that plugs in but is that the only way ? I do not have the remote ? is there any other way to turn brightness up in windows etc >?
BobA
  • What Me Worry?
« Reply #3 on: April 26, 2009, 11:57:23 am »
If your screen has the buttons on a separate remote board then I know of no other way to access the on screen setup without the board.
