Author Topic: power strip and final touches  (Read 2038 times)
Firebat138
  • Last login:January 29, 2026, 02:52:57 pm
  • Head Brewer and Arcade Enthusiast
« on: April 25, 2009, 02:54:37 pm »
Can someone direct me to a GOOD power strip...  I am looking to do the following...
First I want an authentic flip switch on the top...  How would one accomplish this...
Also...  I guess I want the marquee light, speakers, subs...if powered....and everything else to come one when  i boot the computer...etc...  ideas...?
Thanx
Camper
Click below to see my Metal Gear/Splinter Cell Machine... http://forum.arcadecontrols.com/index.php?topic=108360.0
Click below to see my PinCab - PinWARS
http://forum.arcadecontrols.com/index.php/topic,164660.0.html
Zeno
  • Last login:May 12, 2009, 11:22:33 pm
  • Movement is an illusion
Re: power strip and final touches
« Reply #1 on: April 25, 2009, 10:55:49 pm »
Have you tried the Bits Limited strip?
I have it and it works great.
http://catalog.bitsltd.us/
Zeno
Running: MAME
Projects: MK3, Ms. Pacman
Firebat138
« Reply #2 on: April 27, 2009, 08:16:02 pm »
Got the strip....Found something similar at Staples...
So...anyone got any idea on how I would wire a switch on the side or top...
Thanx all
Camper
ivwshane
    • My first mame cab! (WIP)
« Reply #3 on: April 27, 2009, 10:35:22 pm »
I cut off the end of my bitsmart and wired it to a switch and a receptacle.
Since you aren't doing a receptacle then all you need to do is rewire the switch that's built into the power strip. Take it apart and look at how it's wired. Get some similarly gauged wire and extend the existing wire to where ever you want your switch to be.
Firebat138
« Reply #4 on: April 28, 2009, 07:31:11 am »
Great....So after I do that, I would plug my computer into the MAIN and everything else into the other outlets which get turned on when the computer boots....  Will the computer turn ON when I switch the power strip on....Do I have to do anything to the computer to make it do that...I forgot...thanx
camper
garnerb350
    • Hyperspin
« Reply #5 on: April 29, 2009, 09:05:10 am »
The computer wont turn on unless you press the power button on the PC....What I did was mount a regular pushbutton to my cab and had it wired to the on/off switch on my PC...All I do is walk up, hit the switch, everything turns on and when I finish, hit the button again, and the cab turns off...
Firebat138
« Reply #6 on: April 29, 2009, 10:02:47 am »
Is it prety simple to figure out...I am all thumbs at electric stuff..  LOL
mrclean
    • Guscade
« Reply #7 on: April 29, 2009, 01:29:56 pm »
I use this which you can pick up locally at sears for $19.99... When you turn on the PC, the monitor, and the marquee lights up.
http://www.sears.com/shc/s/p_10153_12605_00924031000P
and infact one of the reviews.. not mine, but...
Great Product, October 18, 2007
By Anonymous Reviewer from Altoona, PA
Value   5 5
Durability   5 5
Reliability   5 5
"I purchased this product for use in my MAME arcade cabinet. I wanted to be able to turn everything on and off with a single button, and thanks to this device, now I can. I press an arcade button on top of the cabinet that is wired as the PC power button, the computer boots up and this wonderful device powers up my speakers, monitor, and marquee lights. When i shut the PC down, everything else turns back off. It works great, I couldn't be happier with it. and at $20, it is a great value. I highly recommend it to anyone building their own arcade gaming system."
« Last Edit: April 29, 2009, 01:32:00 pm by mrclean »
2,370,650 Gun.Smoke
ivwshane
« Reply #8 on: April 29, 2009, 02:20:05 pm »
If your computer has a setting to turn on after a power failure then as soon as power comes into the strip it will boot and everything else will turn on as well.
Firebat138
« Reply #9 on: May 01, 2009, 06:02:37 pm »
where would i find that setting?  Is there a program I need to accomplish this...Thanx.
ivwshane
« Reply #10 on: May 02, 2009, 02:22:38 am »
It's located in the bios under power settings and it's something like "turn on after power failure".
