Author Topic: X-Arcade Player 1 Joystick Not Working in MameUI  (Read 4289 times)
Lahey
  • Last login:April 16, 2009, 09:30:23 pm
« on: April 16, 2009, 08:10:09 pm »
Hey all,
I'm having a bit of trouble with my X-Arcade.
I have MameUI 0.124u5 and for some reason the Player 1 joystick doesnt work. The joystick itself is fine, I have tested it in notepad. All the other P1 buttons, as well as the P2 buttons and joystick work fine.
I am using the X-Arcade.cfg file from the X-Arcade website. I re-downloaded it to make sure I have the latest version.
Any help? I don't know what else to do here.  A link to a working CFG file would be awesome :)
Lahey
Re: X-Arcade Player 1 Joystick Not Working in MameUI
« Reply #1 on: April 16, 2009, 09:30:23 pm »
Ok so after fooling around a bit I discovered that this cfg file works with the newest version of MameUI (.130), but it doesn't seem to work for any of the older ones.
This isn't much good to me because a ton of games no longer work in version 0.130 and it seems like it will be a pain to get set up.
I guess I need the older version of the X-Arcade.cfg? Anyone know where I can get that?
9innail
  • Last login:September 22, 2011, 11:18:53 am
« Reply #2 on: April 17, 2009, 03:22:05 am »
Don't use the cfg just press tab and reprogram all the buttons. This has worked fine for my X-arcade tankstick.  :)
garnerb350
    • Hyperspin
« Reply #3 on: April 17, 2009, 11:27:30 am »
Its easy to reconfig the input....ALSO make sure your NUM LOCK key is ON....the player one side joystick works off the keypad....
