Author Topic: How do I know if I need a video amplifier with soft15?  (Read 1416 times)
Mauzy
« on: April 13, 2009, 05:28:30 pm »
I need some clarification here. I have a Pentranic 1132 (or 1123... whatever it is it uses the CH-288 chassis), standard resolution that I want to use with soft15. I've used this monitor before with soft15 with an excellent picture once in a game, but this was done with admittedly embarrassing ignorance of proper procedure. I let it run in boot up with a screwed up screen and I'm sure I wasn't using a proper resolution. This was all about a year ago. I only did this for a week, then went back to normal JAMMA games. Luckily no noticeable damage has been done. Now that I know a little more, I'm wondering if a video amplifier is necessary. Like I said I had gotten a great image once in a game, but I don't want to go and damage anything. I'm planning on a permanent MAME-ing of this cab in the near future, and I want to do it with the safety of my components in mind.
Also, am I correct in thinking that the DOS screens and everything that comes up before the computer puts out the 15khz signal can damage the monitor?
Level42
Re: How do I know if I need a video amplifier with soft15?
« Reply #1 on: April 14, 2009, 06:20:20 am »
I don't know that monitor but since you mention it's standard res and in a Jamma cab I assume that it requires TTL level signals (5V). VGA is only 1V so too low, although you probably will get a picture.
The thing you need is a J-pac. Video amp on bourd, blocks the wrong synced boot-up screens and provides the easiest way to interface the controls to the PC.
Mauzy
« Reply #2 on: April 14, 2009, 08:29:26 am »
Hmm... didn't know the J-PAC had an amplifier. Im good then. Was planning to get one anyway!
