Author Topic: Re-programming the Mini-PAC - Help! [SOLVED!]  (Read 1438 times)
dekar24k
  • Last login:April 28, 2019, 03:50:11 pm
    • ArcadeForum.com
« on: April 13, 2009, 09:34:56 am »
Hi guys!
I'm sooo close to finishing my bartop cabinet now, but I am stuck programming the Mini-PAC interface.
When I wired the buttons and joystick I didn't pay attention to the labeled connectors on the Mini-PAC and I just connected them randomly as they fit. I didn't think this was going to be a problem as I read that the Mini-Pac could be re-programmed completely.
Now, when I push "Up"/"Down" on my joystick it may output the characters 'X' and 'G' instead of 'Uparrow' and 'Downarrow'. I would therefore want to change this so when I push the joystick up, it sends the keyboard character for "Uparrow" to the computer.
Basically, how do I change what keyboard characters the different switches output to the computer? I tried using the WinIpac application from Ultimarc, but I couldn't figure out how to do it there.
All help appreciated a lot. :)
« Last Edit: April 13, 2009, 01:54:07 pm by dekar24k »
Finished project: "The Saloon Arcade" - 2 player upright cabinet
Joystick.net - Retro gaming news and reviews
Neverending Project
    • Arcade Fixer
Re: Re-programming the Mini-PAC - Help!
« Reply #1 on: April 13, 2009, 12:34:36 pm »
Did you read through the documentation here? The Win-Ipac utility is really what you need to reprogram it.
dekar24k
    • ArcadeForum.com
« Reply #2 on: April 13, 2009, 12:37:43 pm »
Hmm .. I thought I'd read through it well enough. The application doesn't seem that complicated to me. :) Guess I'll have to try again. Thanks!
dekar24k
    • ArcadeForum.com
« Reply #3 on: April 13, 2009, 12:44:55 pm »
Ergh.. Guess I was a little too quick when rushing through the WinIpac util. I get it now. I have to assign each button according to how I physically wired it in "Panel mode" first, then I can assign keyboard codes.  :P Ah.. I hope it's possible to reset the MiniPAC to it's default configuration, because I messed around and saved a new configuration to the ROM which screwed it up completely. ;)
« Reply #4 on: April 13, 2009, 01:10:03 pm »
You can reset it by going into "Programming Mode" in windows notepad.
http://www.ultimarc.com/interact.html
dekar24k
    • ArcadeForum.com
« Reply #5 on: April 13, 2009, 01:53:53 pm »
Awesome, thanks! :) I guess I'll program the Mini-PAC in programming mode as well (instead of using WinIpac). Thanks again!
