Author Topic: Newbie - Galaxian PCB problem  (Read 1915 times)
fazz
  • Last login:April 13, 2009, 09:52:09 am
« on: April 13, 2009, 09:25:57 am »
Hi
I have acquired two galaxian boards, one logitech and one midway.
I am trying to run in a jamma cab using this http://lizardlick.com/images/parts/adapters/galax2j.jpg
The Midway one has no daughter board and just gives a few coloured blocks, so i think I was sold a pup with this one.
The logitech one appears to work fine and I have played the game successfully but I am getting NO sound, I have adjusted the volume adjuster on the board  but this has not helped.  I was wondering if there is something else I need to do, if its something to do with the adapter im using or if the pcb is faulty.
Any pointers or suggestions most welcome.
OldTymeToys
  • Last login:July 28, 2020, 09:29:32 am
Re: Newbie - Galaxian PCB problem
« Reply #1 on: April 15, 2009, 03:40:51 pm »
Hi
You may find your answer over on the Klov boards- those guys are experts on stuff like this: http://forums.arcade-museum.com/
