Author Topic: Monitor shrink+expand  (Read 2038 times)
ken_cinder
  • Last login:October 22, 2010, 10:38:18 pm
« on: April 07, 2009, 10:11:56 pm »
Having a problem with one of my Nanao MS9-29A monitors, the picture will shrink and expand slightly when what is on screen changes.
Example: Dark title screen showing, fades to black and then a significantly brighter gameplay screen comes on and the screen shrinks and expands back to normal.
It's not staying like that any longer than a second or two, but it's still annoying and I want to stop it.
I tried adjusting B+ and that's not fixing it, adjusting screen level doesn't seem to help either.
What sort of things commonly cause this?
Wanted - TMNT artwork (CPO, Sideart, and Marquee)
Aero Fighters artwork (CPO and sideart)
Items for sale ChaseTheChuckWagon Vendazzle
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Monitor shrink+expand
« Reply #1 on: April 07, 2009, 11:00:49 pm »
may be a problem with vreg .  i.e. failing to maintain regulation with varying load conditions.
a weak crt can have a similar symptom ( blooming )
qrz
ken_cinder
« Reply #2 on: April 07, 2009, 11:14:49 pm »
I was thinking it could be voltage related. It's a 100v monitor, running on 115v. I was told "It's fine, don't worry about it!" but I'm starting to wonder and have been thinking of getting a transformer to throw in there.
qrz
« Reply #3 on: April 07, 2009, 11:34:28 pm »
a functioning vreg shouldn't have much difficulty with that .
the line voltage from a household outlet WILL vary some , and that varience will be passed by the isolation xformer.
there are a couple of types of regulators used .
linear.  with this type , the dc input voltage must stay higher than the regulated vout to maintain regulation.
effeciency is around 60%
smps.  this type varies either the frequency or pulse width of a oscillator driving a xformer.
due to the high frequency ops, filtering components can be smaller . it uses more overall components than a linear supply. but , has effeciency ratings above 90%.
it does not require an isolation xformer as that is part ot the supply
qrz
ken_cinder
« Reply #4 on: April 08, 2009, 12:47:25 am »
These monitors don't require an isolation transformer.  :dunno
Kevin Mullins
    • Me on Myspace
« Reply #5 on: April 08, 2009, 01:00:10 am »
Does the B+ fluctuate in conjunction with the screen flucuation?
ken_cinder
« Reply #6 on: April 08, 2009, 01:01:56 am »
Not sure, I haven't measured (Not quite sure where to do so correctly really).
