Author Topic: Freebox (E-Touch) ActiveX Error  (Read 2564 times)
Fordman
  • Last login:September 12, 2021, 11:20:27 am
  • MADE in the USA
« on: March 26, 2009, 10:55:33 am »
Hello All,
Since the E-Touch - Freebox Site and forum is down again, I have an issue.
When I try to run the Configurator
I get an error that says 'Runtime Error '429': ActiveX Component can't Create object' ???
Any thoughts?
Thanks,
Fordman
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
Re: Freebox (E-Touch) ActiveX Error
« Reply #1 on: March 26, 2009, 12:12:51 pm »
What are you exactly trying to do? Do you get the error on launching, or when trying to perform a specific function?
Fordman
  • MADE in the USA
« Reply #2 on: March 26, 2009, 06:24:39 pm »
I'm trying to add music to my library with the configurator. I tap the 'Generate Library' Button, it finds what I want to add, the I tap 'OK' then that is where I get the error.
Hope that helps,
Fordman
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #3 on: March 26, 2009, 08:38:29 pm »
Ok so you are using generate DB. Is this on a fresh install, also what version are you running. You might be better off mailing me as i will probably need a couple of screenshots. Are you trying to resize covers? It just seems odd you are getting an active X error from the config.
Actually searching that error on google seems to indicate you may have a missing file or a different version than freebox is expecting to find.
Fordman
  • MADE in the USA
« Reply #4 on: March 27, 2009, 10:18:30 am »
Hi Barry, Check Your PM!
Thanks,
Fordman
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #5 on: March 27, 2009, 10:24:54 am »
Ah so it was a windows error. Glad you got it sorted out dude, i did wonder why no one else had reported it.  :cheers:
