Author Topic: A qyestion for the Electrical Guru's  (Read 2969 times)
Fordman
  • Last login:September 12, 2021, 11:20:27 am
  • MADE in the USA
« on: March 13, 2009, 05:34:10 pm »
Hello All,
I bought 2 Lumin Disks and I need to know if I can direct wire them to the PC power supply. The power adapters that came with them say 12V-500ma. I just need to know if connecting them the the PC power supply will harm them in any way?
Yes ?  No ?
Thanks for the time,
Fordman
Kevin Mullins
    • Me on Myspace
Re: A qyestion for the Electrical Guru's
« Reply #1 on: March 13, 2009, 08:25:37 pm »
Is the power supplies that came with them 12v AC or DC ?
Fordman
  • MADE in the USA
« Reply #2 on: March 13, 2009, 08:53:25 pm »
Thanks for the help! The Lumin Disks say 'AC' so I assume you can connect them to the PC Power supply ?
MonMotha
« Reply #3 on: March 13, 2009, 09:07:18 pm »
PC supply outputs DC.  Likely a no-go if the device requires AC.  There are some circumstances under which they may work, but then there are also plenty of circumstances under which you'll melt things.  Just use the brick that came with it.
Fordman
  • MADE in the USA
« Reply #4 on: March 13, 2009, 09:19:58 pm »
Looks like I'll just use what came with them to power them up!
Thanks All for the help!
Fordman
panama1974
  • Last login:June 15, 2014, 08:22:30 am
« Reply #5 on: March 14, 2009, 08:39:59 am »
 :angel:   Electronic reducers sold 110 volt ac 12 volt ac, here in my country is about 7 dollar in your country may be about the same price.
