Author Topic: Home Electricians - Question for You  (Read 1282 times)
kenzo42
  • Last login:November 23, 2024, 01:11:32 pm
« on: March 12, 2009, 02:08:44 am »
I need to ground an Japanese arcade cabinet however, there is no ground prong on the plug (only 2 prong plug).
There is however a ground bolt connecting noise filter, earth ground on the harness, and coin mechanism that should be grounded.
1) Can I just connect the ground bolt (via wire) to the power outlet screw? It says explicitly on the power outlet to not use the bolt as a ground. My outlets are 3 prong type.
2) What's the worse if I just don't connect any grounds?
« Last Edit: March 12, 2009, 02:26:34 am by kenzo42 »
grantspain
Re: Home Electricians - Question for You
« Reply #1 on: March 12, 2009, 03:30:12 am »
the japanese earth their cabs via that bolt and daisy chain the earth to the cabs,you can put an earth wire straight to that bolt
better still would be to change the mains lead to a standard one and find an earth point inside the cab
not having an earth will give certain people a half mains electric shock if they touch the cab and an earthed item at the same time
