Author Topic: WG436233 Specs?  (Read 2647 times)
chinabox
  • Last login:January 04, 2009, 10:10:05 pm
  • I'm a llama! No, really, I am...
WG436233 Specs?
« on: June 27, 2003, 09:22:56 pm »
I opened up my Championship Bowling Machine (1989) and found a WG436233.  Does anyone know where I can get specs of this monitor?  I tried their website, but didn't find anything.  Any help?  Is it 15Hz?  Basically, I'm wondering if I can buy an ArcadeVGA for it...
Thanks,
Zach
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:WG436233 Specs?
« Reply #1 on: June 27, 2003, 10:06:35 pm »
I'd email andy at ultimarc to be sure...
Dollars to Donuts it is... because according to klov Championship bowling used a standard res 15khz monitor...  (although klov had it listed as horizontal...so how accurate is that?) =P
I checked here but he had every monitor but yours...
*Shrug*
Mostly likely you can... but check in with Andy if you have any doubts via email.
Rampy
chinabox
Re:WG436233 Specs?
« Reply #2 on: June 27, 2003, 10:39:50 pm »
Yeah, it's definetly not horizontal.  However, it can easily switched to vertical--not that I'm saying it should be listed as "vertical" :)  Does anyone know what the specs of this monitor are?  I have a sinking feeling it's one of those 25Hz ones or something... ::)
Zach
rampy
  • *shrug*
Re:WG436233 Specs?
« Reply #3 on: June 28, 2003, 09:17:19 am »
Zach
In case I wasn't clear earlier...more than likely it's a 15khz ... but I'd email andy if you have questions about compatibillity with your monitor.
You can also drop Wells Gardner a line... they may give you the basic info you need... couldn't hurt.
BTW are you sure that's the model number?
Good luck,
Rampy
Birdtales
  • Last login:October 06, 2020, 10:00:31 am
  • You won't like me when I'm angry.
    • Birdtales
Re:WG436233 Specs?
« Reply #4 on: June 28, 2003, 06:01:28 pm »
Looking at the picture of the monitor from the other thread you have going on the main board I'd say thats a K7000 series chassis. 15KHZ check here and see if you can find a match...
http://www.dameon.net/BBBB/monitor.html
Coming Soon
Ken Layton
  • Guru
  • Technician
Re:WG436233 Specs?
« Reply #5 on: October 29, 2003, 11:00:17 am »
The number you mentioned sounds more like the serial number. Can you provide a picture of the monitor circuit board? I strongly think you have a standard resolution (CGA) monitor.
