Author Topic: More than one rom extension in MameWah  (Read 2178 times)
MrPoPo
  • Last login:March 10, 2004, 05:53:46 pm
« on: June 27, 2003, 07:24:59 pm »
Hi group !!
How can I add more than one rom extension in the definition of the emu.cfg file in mamewah??
I want to add to my main list of the gens emulator two types of roms zip and iso.I must to make two different emu configs ??
Thank you.
« Last Edit: June 27, 2003, 07:26:22 pm by MrPoPo »
Syxx
  • Last login:June 25, 2006, 06:36:25 pm
  • Bling Bling
Re:More than one rom extension in MameWah
« Reply #1 on: June 27, 2003, 11:48:36 pm »
just zip the non zipped ones, other wise it probably wont work. but you can try using "*" in the extension part, so try * but it will make it show EVERYTHING in that folder. so make sure its only the roms in that folder. otherwise just zip the others.
MrPoPo
« Reply #2 on: June 28, 2003, 04:15:59 am »
Thanks but this don't work.
If I put the iso and the mp3 files of audio tracks in one zip, the emu can't find the audio files.
If I select * the extensions and the mp3 are unzipped, mamewah takes them to its mainlist.
meta87
  • Last login:September 30, 2004, 07:36:28 pm
  • Dont Mess with Texas
« Reply #3 on: June 28, 2003, 09:40:47 am »
I think he meant to put each mp3 in its own zip file :)
Syxx
  • Bling Bling
« Reply #4 on: June 28, 2003, 01:09:34 pm »
not sure then, guess you can add to another list, or just do a second emulator for it. sorry i didnt understand what you ment. i havnt messed around with segacd/iso files [im guessing you were using sega cd?]
  • Last login:June 19, 2026, 12:33:17 am
« Reply #5 on: June 28, 2003, 07:36:21 pm »
This is a common problem for many front ends, but there isn't the solution that you want.
You have two options....
1.  Use a converter so that all of the files are converted to the same type.
2. Make two different emulator setups, with identical settings except for the extension.
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
« Reply #6 on: June 28, 2003, 07:59:34 pm »
i had this problem w/ gens FE, using mamewah. what i did was i made two different emulators (SEGA CD and SEGA GENESIS), with same executable. then i just had two .cfg files, each with a different type of file extension. also a bit more organized as well
It's all about the Pentiums
