Author Topic: Well Gardner U5000 issues  (Read 1422 times)
claysred
  • Last login:July 14, 2016, 08:02:07 pm
« on: March 09, 2009, 08:54:52 am »
I have a WG U5000 monitor that was squished at the bottom of the screen.  I called WG and bought the 3 service kits and a cap kit.  I installed all three kits and the cap kit.  Upon firing the monitor up, the bottom of the screen was still squished, and the image was upside down.  I figured I had hooked the yoke wires up backwards, so I removed the yellow & green yoke wires and reversed them.  The image now was correct vertically, but was backwards left to right.  SO, I grabbed the red & blue yoke wires and reversed them.  Of course I did it powered up and when I did this last swap, the monitor went blank and will not power up.  No neck glow, nothing.
Can someone send me in the right direction.
grantspain
  • Last login:July 25, 2025, 09:21:43 am
Re: Well Gardner U5000 issues
« Reply #1 on: March 09, 2009, 09:25:06 am »
the U5000 does not like anything like this done to it,I should know I blew the crap out of one by leaving the control pcb disconnected
It could anything causing this,my guess though is that the HOT has blown
the only advice i can give is go to the WG website and download the repair guide and go through everything relevant to your fault
Ken Layton
  • Guru
  • Technician
« Reply #2 on: March 09, 2009, 12:14:49 pm »
Never never never never never connect/disconnect the yoke or the remote adjustment board while the monitor is powered up!
Severe damage may result.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #3 on: March 09, 2009, 10:20:09 pm »
as per Grant,  hot failure.
removing the h yoke connection greatly increased the "on time" for the xistor .
the increased current/thermal load caused it to fail.
note: there is roughly a 1200vpp pulse present on the the xistor side of the h yoke.
so, you really don't want to mess with it while active circuitry ...  ;)
qrz
