Author Topic: Two Ultrastick 360 crashes my machine  (Read 1637 times)
Rowdy
  • Last login:March 22, 2009, 08:47:55 am
« on: March 05, 2009, 09:28:12 am »
I'm finally finnish with my cab and are installing the software. But when I plugged in the sticks the computer just went black and restartet.
When I start Ultramap with both sticks and the drivers are loading: restart.
With just one stick (no matter which) everything is fine.
What is the problem? Anyone experienced this before?
Hw/sw:
Mb: Gigabyte GA-P35-DS3
CPU: E6600
RAM: Corsair 1gb
HD: Samsung 160gb
GPU: ATI 3650
Windows XP Pro SP3
Ginsu Victim
  • Comanche, OK -- USA
Re: Two Ultrastick 360 crashes my machine
« Reply #1 on: March 05, 2009, 11:12:45 am »
Did you plug in only one first, set its ID, then the other and set its ID? (As you're supposed to)
Or did you just plug both in from the start?
Rowdy
« Reply #2 on: March 05, 2009, 11:32:09 am »
Yes, I just plugged inn both at the same time. But now I have been playing with the one stick for a while and everything is fine. It is set as ID #1 (without me doing this). But the second I connect the second stick (with or without UltraMap open), the machine shut down and restarts.
fatfingers
  • Got UltraStiks?™
« Reply #3 on: March 05, 2009, 12:10:25 pm »
I think what Ginsu is getting at is they need separate IDs.  Plug the first one in.  Set it's ID to 1.  Unplug it.  Plug the 2nd one in.  Make sure it's ID is 2.  Unplug it.  Now plug the first one in, then the 2nd one.
Good luck.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
Ginsu Victim
« Reply #4 on: March 05, 2009, 12:21:06 pm »
exactly
Rowdy
« Reply #5 on: March 05, 2009, 12:54:04 pm »
YES! That did it. Thanks!!  :applaud:
Ginsu Victim
« Reply #6 on: March 05, 2009, 03:16:36 pm »
Awesome, glad it worked.
