Author Topic: Where can I get or how can I build a Jamma connector cheaply?  (Read 1296 times)
slapaham
  • Last login:January 31, 2012, 05:32:32 pm
Basically, I want a lead that runs from the 56 pin connector on my supergun to the connection on the pcb - my supergun board is fine plugged upto a pcb but I would really like a bit of flexibility rather than having them stuck to each other.
I don't want to pay much for a solution and I like to avoid soldering if I can... I live in the UK but don't mind importing a solution if needs be...
srarcade
  • Last login:June 18, 2018, 03:16:29 pm
Re: Where can I get or how can I build a Jamma connector cheaply?
« Reply #1 on: March 04, 2009, 08:07:45 pm »
You need a jamma extender harness which is plug in play. I don't know about UK shops, sorry. I usually order all my jamma related harness parts from these guys:
http://www.jammaboards.com/store/jamma-extender-harness/prod_247.html
Im sure theres a UK online shop that has the same item.
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #2 on: March 04, 2009, 10:16:53 pm »
Try ebay. When I owned a Supergun there were a couple of dudes offering conversion connectors and extension harnesses just like that.
« Last Edit: March 05, 2009, 01:38:45 pm by Turnarcades »
slapaham
« Reply #3 on: March 05, 2009, 03:53:45 am »
Thanks people!
I guess I've just have to keep a lookout! It seems like it would be a sensible option as yanking the supergun board around doesn't seem like a good option (when I say 'yanking', I'm, of course, as careful and gentle as I can be ;D but an extender would certainly make things easier!)
