Author Topic: Marvel VS Capcom 2 and Playstation 3  (Read 1515 times)
Jawknee7o7
  • Last login:September 30, 2013, 09:55:30 pm
« on: March 01, 2009, 02:19:18 pm »
In the beginning of the month I got a 34" showcase cabinet that had Marvel VS Capcom 2 on the Naoki System i think it is.  i dont know too much about wiring and thought i could turn this way for imformaton.  In other words i am a noob at this.  basically what i want to do is hook up my Playstation 3 up to my cabinet so i can play my PS3 on the cabinet so i can play SSF2THDR and eventually SF4 when i get it.  is there any easy why and how would i go about doing this.  Thanks for your help in advance.
Jack Burton
Re: Marvel VS Capcom 2 and Playstation 3
« Reply #1 on: March 01, 2009, 02:39:42 pm »
In order to connect controls to the playstation 3 I recommend using two Cthulu boards from lizardlick.com
http://www.lizardlickamusements.com/pages/boards.shtml
You will also need a method to connect your PS3 to your monitor.  The first step toward that is telling us what the model number for your monitor is.  After that you may need to buy a converter.
Jawknee7o7
« Reply #2 on: March 02, 2009, 07:45:24 pm »
the monitor that is in there would be a 34" CGA monitor (model SI-134).  as for the controls, from the arcade stick that it hooked up to the jamma harness and the jamma harness plugs into something else (middle box in picture) and from that goes into the naomi system (box on the right) via USB, would i be able to use that usb hook up to the ps3.
