Author Topic: Fxing Sound Issue  (Read 1224 times)
REBIRTH
  • Last login:December 28, 2023, 09:10:29 pm
  • What is that?
    • REBIRTH "Rotating Arcade"
Fxing Sound Issue
« on: June 26, 2003, 05:04:26 pm »
I am sure this has been discussed, but I can't find it after many searches.  For sound problems related to the PC hardware not being up to snuff, what is the normal recomended first strike at upgrading to fix it?  I have a 500mhz P3 with 512mg Ram and a Creative Labs PCI 128D sound card - and certain games, like Shuffle Shot, will run at about 35 FPS which is bearable - but the sound echoes (everything is repeated twice).  This sound issue happens with a few of the more hardware intensive games.  I plan on getting a much better PC in 6 months or so, but for now I'm wondering if there is a quick fix for this.
To remedy a problem like this would the first upgrade option be a new sound card or more RAM (or nothing if this is normally stricly a processor issue)?
:) Rotate or die! :)
Odonadon
  • Last login:January 27, 2006, 12:01:12 am
  • But then again, that's just one man's opinion.
    • Turbo2k
Re:Fxing Sound Issue
« Reply #1 on: June 26, 2003, 05:53:32 pm »
Are you able to use DOS?  I have the same problem in Windows, but in DOS it's non-existent.  Unfortunately, because of my choice of other emus, I can't use DOS :)
Odonadon
It's Captain Odonadon, and his magical bag of nuts.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: June 27, 2003, 04:20:00 am »
First, try increasing the sound latency (to "audio_latency 5" in mame.ini).  Other thing is to try decreasing the samplerate (to "samplerate 22050").
CPU, CPU, CPU.  WIth 512 megs, your memory is not the problem.  A sound card upgrade, although possible, is very doubtful of doing anything.
Robin
Knowledge is Power
