Author Topic: UltraStik 360 and MaLa  (Read 2808 times)
Onyx_PghPA
  • Last login:January 20, 2011, 06:03:02 pm
« on: February 26, 2009, 01:13:51 pm »
This might be more of an UltraStik issue rather than a MaLA issue, but I thought I'd try here. I tried to ask this question on the Ultimarc message board, but never received a response.
I recently replaced all of the PC components in my cabinet (new motherboard, CPU, RAM, hard drives, etc.) and installed Windows XP Professional (64-bit). I've always used MaLa as my front-end and I also have the UltraStik plug-in installed. For emulation, I'm running the 64-bit version of MAME 0.129. I've replaced my shell with MaLa so that the cab boots directly into it.
The problem I'm running into is that when the cab first boots up, I receive an UltraStik pop up box indicating "Programming all plugged in UltraStiks," but with this additional info:
"The following errors were encountered. UltraStik #1 should be plugged in but cannot be found."
I've gone into the Game Controllers section of Control Panel and verified that the 360 is recognized. The stick itself and all of the buttons test fine. Although I doubted it would make a difference, I tried different USB ports, but to no avail.
Is the problem possibly with my installation of the UltraStik software? Could it be the MaLa plugin?
Before I upgraded, I was running everything in 32-bit. Could this be a problem with 64-bit Windows, or 64-bit MAME?
Anyway, if anyone has an idea, please let me know.
Joe
« Last Edit: March 12, 2009, 05:15:29 pm by Onyx_PghPA »
"mmmmm...control panel finished... <drool>"
fatfingers
  • Got UltraStiks?™
Re: UltraStik 360 and MaLa
« Reply #1 on: February 26, 2009, 08:21:36 pm »
I really have no idea what's wrong, but are you sure you have one of the joysticks assigned to ID #1?  If not then perhaps you should.  Well, that or turn off the 'required sticks' (or whatever it's called) in the UltraMap software.
Good Luck.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
Ummon
  • Trade Count: (+13)
« Reply #2 on: March 01, 2009, 05:23:32 pm »
This sounds like the same issue others've had with 32-bit. #1 stick isn't seen, and re-organizing the numbers in firmware (via Ultramap) is required.
Yo. Chocolate.
Stephen Hawking
Onyx_PghPA
« Reply #3 on: March 12, 2009, 05:18:03 pm »
May have to contact Andy for more info, but just wanted to follow up.
Getting rid of the error message isn't my main issue, although I've done it at this point because the Ultimarc app seems to want to take focus, preventing simple functions like ESC from working in MaLa.
So, I've made the error message go away by preventing everything from trying to load, but this defeats the purpose of having the stick to begin with!
Still looking for help.
Thanks,
Joe
