Author Topic: Bob Roberts said to clean leafs with a business card , other methods ?  (Read 3398 times)
mrclean
    • Guscade
can i dunk my wico leafs in some solution to clean the contacts on old leafs ?
2,370,650 Gun.Smoke
Level42
Re: Bob Roberts said to clean leafs with a business card , other methods ?
« Reply #1 on: February 15, 2009, 06:13:53 pm »
Why doubt one of the icons in the hobby/business.
Did you actually try it ? I have, and it works great :)
Kevin Mullins
    • Me on Myspace
« Reply #2 on: February 15, 2009, 06:16:11 pm »
The idea is you want to be gentle on them.
Not to "file" or "sand' them.
It doesn't take much to remove the general tarnish off.
You could possibly use a dab of something like Tarn-X if you wish.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #3 on: February 15, 2009, 06:59:08 pm »
If you are skeptical, check the continuity with a meter. It doesn't take much to clean them up.
Working: Not Enough
Projects: Too Many
Progress: None
SirPeale
  • Green Mountain Man
« Reply #4 on: February 15, 2009, 09:58:19 pm »
dollar bill
coin wrap
piece of denim
doesn't take much.
mrclean
    • Guscade
« Reply #5 on: February 15, 2009, 10:26:16 pm »
I never said i doubt bob, i just wanted to know other methods that people have used.
2,370,650 Gun.Smoke
channelmaniac
  • Last login:May 11, 2019, 12:36:18 am
    • Arcadecomponents.com
« Reply #6 on: February 16, 2009, 12:15:25 am »
VERY fine sandpaper... 400 grit or higher and a very fine touch.
If they are badly pitted or corroded then use a Point File on them. You can pick those up at your local NAPA Auto Parts store. Just be gentle! It doesn't take much to restore them to smooth operation.
RJ
Call me a cheap bastard... I learned to fix things to save money... even surface mount soldering...
Visit my website: http://www.arcadecomponents.com
My repair logs are kept at: http://newlifegames.net/nlg/index.php?board=19.0
Level42
« Reply #7 on: February 16, 2009, 02:21:34 pm »
RJ
A file will get the extremely thin layer of gold (IF it are gold-plated contacts) off in no time. Not the best option.
Even Atari endorsed the business card solution in their "The Book" (a must read: http://arcarc.xmission.com/PDF_Arcade_Atari_Kee/Atari_TM-129_The_Book.pdf)
mrclean
    • Guscade
« Reply #8 on: February 16, 2009, 05:19:56 pm »
Who sells NOS wico just the "leafs" ??? I ordered a 4pack from bob a while ago repro and they don't fit my wico's.
2,370,650 Gun.Smoke
Level42
« Reply #9 on: February 16, 2009, 06:45:21 pm »
Now _there's_ a flaw of good old Bob. Selling the cheapo Chinese Wico fake crap.
Even if they would fit, you probably won't be using them for long....terrible quality.
Got a pick of the leafs ? Pretty sure there are fitting replacements around.
Pac-Fan
  • Last login:February 05, 2014, 09:30:12 am
« Reply #10 on: February 23, 2009, 11:25:03 am »
Fiberglass pencil works wonders. It removes the oxidation but does not scratch/pit the contact.  It's kinda hard to get in at an angle and must be done with the leaf off the panel, but is very gentle and shines them up much better than a business card can.
Alternatively, you can soak a business card in electronic contact cleaner to help with polishing the contacts better.
TheShanMan
    • My Arcade (updated 1/30/13)
« Reply #11 on: February 23, 2009, 12:40:05 pm »
I tried a business card with mine but that wasn't sufficient - my contacts were horribly tarnished. I carefully used very fine sandpaper and it worked wonders.
mrclean
    • Guscade
« Reply #12 on: February 23, 2009, 01:21:06 pm »
Yeah they work with lizardlicks chinese repro knockoff wico sticks etc.. here is a pic of the repro ones that bob sells for 4 bucks a pack that does not work well with the wico bases. I got lucky and was able to track down some NOS Wico Leafs for my project.
Someone on KLOV said and i'd agree with them if someone were to actually make a good repro for the wico bases they would make a TON of money!
« Last Edit: February 23, 2009, 01:22:49 pm by mrclean »
2,370,650 Gun.Smoke
channelmaniac
« Reply #13 on: February 26, 2009, 06:54:26 pm »
RJ
If they are badly pitted or corroded they are beyond a business card. Hence... the need. It's either that or replace them.
