Author Topic: Needed - Williams Phoenix CPU Board Schematic  (Read 3271 times)
bowman9
  • Last login:May 19, 2009, 09:44:55 am
« on: February 14, 2009, 01:04:41 pm »
Hello all,
I just recently picked up a 1978 Williams Phoenix Pinball that needs some TLC.
I am in need of the schematic for the main cpu board so I can replace some transistors on the board that are broken.  The printing on the transistors is worn off and can not be identified.  Does someone here have the schematic or a component list for the system 4 board or knows where to find one?
Just trying to get her up and running at the moment.
Thanks,
Bowman9
bowman9
Re: Needed - Williams Phoenix CPU Board Schematic
« Reply #1 on: February 14, 2009, 03:08:47 pm »
I found what I was looking for over at :
http://www.pinrepair.com/sys37/index1.htm
But I am sure I will be back with other questions :)
Bowman9
bowman9
« Reply #2 on: March 01, 2009, 07:29:01 pm »
Okay are there any other Williams system 4 owners out there?
I am in the process of cleaning up the main board (from a battery explosion) and need to replace a couple of chips, what I need to know is if the IC18 5A-8972 MC6820 PIA chip has programing on it or if it is just a blank chip for processing information.
Any help would be great.
Bowman9
