Author Topic: CP Lexan/Plexi questions.  (Read 1663 times)
Fordman
  • Last login:September 12, 2021, 11:20:27 am
  • MADE in the USA
« on: February 13, 2009, 08:52:10 am »
Hello All,
I have been reading for quite some time and I have to say there are some very talented craftsmanship here.
On to my questions:
I have built my CP but I want to put Lexan/Plexi over the top. I dont want to debate Lexan vs plexi. Does the Lexan/Plexi just sit on top of the CP and only held down with the buttons? I've seen some using screws but I don like that look. If the buttons are holding it down, is that enough to keep it down all the time?  :dunno
Also is the Lexan/plexi flush with the t-molding or is it just slightly higher than the t-molding?  :dunno
or did every one just buy the 23/32'' (not quite 3/4") plywood and the Lexan/Plexi just naturally kinda flush with the t-molding? :dunno
I will start to post pics soon of my cab.
brock.sampson
  • Last login:May 31, 2018, 10:11:41 pm
Re: CP Lexan/Plexi questions.
« Reply #1 on: February 13, 2009, 09:07:54 am »
The two I have made the plexi is just held down by the buttons.  I have quite a few buttons on my cp so it may depend on your cp size and layout.  My t-molding is level with the top of the plexi, I used 5/8" particle board and and 1/8" plexi.  You can get away with using 3/4" and chamfer the bottom of the cp top like Mountain did http://forum.arcadecontrols.com/index.php?topic=63629.0
DOC! YOU HAVE A TABLE OVER THERE WITH A SIGN THAT SAYS, "LASER DEATH RAY BARGAIN BIN!"
Fordman
  • MADE in the USA
« Reply #2 on: February 13, 2009, 09:42:11 am »
Thanks for the help.
I have looked at 5/8" ply or mdf, just didnt feel that strong to me with all the button mashing and people leaning on the CP ( I have 3 yr old son and a 4yr old grandson ).
I have read the whole 'Mountain' thread and is very informative. Althouh my skills arnt what his are, I will try his techniques.
Thanks, Again!
Fordman
ViciousXUSMC
  • Last login:July 28, 2009, 10:25:53 am
« Reply #3 on: February 13, 2009, 10:39:21 am »
Im new to wordworking so my guess may not count for much but see no reason you could not use a flush trim bit to bring the t-molding down the right size, or maybe better yet a roundover bit so it has a nice soft edge.
brock.sampson
« Reply #4 on: February 13, 2009, 11:25:58 am »
Thanks, Again!
Fordman
I have a 6 yr old and 9 yr old son.  I haven't had any problems with them and their friends mashing the keys and cranking on the joysticks in 2 years of frequent use.
ivwshane
    • My first mame cab! (WIP)
« Reply #5 on: February 13, 2009, 12:50:24 pm »
Thanks, Again!
Fordman
If you are concerned about strength then add another layer of ply to the underneath of the cp but only in the middle.
daok
  • Last login:July 04, 2009, 09:30:00 pm
« Reply #6 on: February 13, 2009, 01:09:35 pm »
I am building an arcade machine and what Brock wrote is almost the samething as me. I used 5/8 MDF and 1/8 Plexi. The molding is 5/8 to fit all the rest of the machine... I simply glued the molding for the panel at the top (so I have a 1/8 of MDF at the button without Molding BUT since I plan to paint the MDF in black, it will be almost invisible).
