Author Topic: Mala Mameroom Layout Issue (SOLVED)  (Read 2781 times)
Spinach
  • Last login:June 14, 2009, 10:55:38 am
« on: February 06, 2009, 11:12:01 pm »
I am having trouble with the Mameroom layout on my PC.  I can get everything working fine on one computer but not the other.  On my PC I get the arcade pic with chalkboard, etc, and the Marquee and list, but no screenshot or anything else.  I did not change any names or folder names, and the snaps match the roms.
Any thoughts?
FYI, I have already deleted and reinstalled the mameroom layout, no good.
« Last Edit: February 10, 2009, 05:31:21 pm by loadman »
loadman
  • Moderator
  • Last login:Today at 05:56:09 am
  • MaLa FE developer
    • MaLa
Re: Mala Mameroom Layout Issue
« Reply #1 on: February 07, 2009, 01:58:38 am »
I would check the path to the snap folder etc is correct.
Spinach
« Reply #2 on: February 07, 2009, 08:44:21 am »
I've done that, all seems to be OK.
Could it be that I copied the files from another computer and it renamed them somehow?  I checked the names and that doesn't seem to be the case.
I have folders set up as:
Mame
   >  snaps
         > Marquees
         > Screenshots
         > Cabinets
         > Controls
I list the snaps to snaps and the marquee to marquees
I have no control panels yet.
With the mameroom layout the marquee and screenshots would show up, on this computer, only the marquee is visable.  All other settings are identical when I go into options while in MaLa.
Spinach
« Reply #3 on: February 10, 2009, 04:36:17 pm »
Solved!
For anyone interested (or reading this board looking for answers) the solution was:
I had to copy and paste the text file into Windows through Control > Fonts.  I also changed the screen resolution to 1024 (?)
I use Window XP home edition.
I can't believe that was the problem, but BAM!  There it is, running fine.
Spinach
Sardu
  • Last login:April 08, 2023, 05:45:54 pm
« Reply #4 on: February 11, 2009, 07:36:07 am »
Solved!
Spinach
That's strange.  What text file?
That's good that you got it working though
