Author Topic: mamewah and pc games  (Read 1978 times)
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« on: June 25, 2003, 12:42:10 pm »
I have been attempting to get pc games working on mamewah but have had no luck.  I have read numerous other posts for answers to my problems but haven't come up with a solution.
I am running version 951b.  I went into the cfg file and updated the executable to 'pc', made a folder with shortcuts to my pc games and set up the rom path accordingly.  When I refresh my game lists it shows shortcuts to the available games but when I go to select any one of the games nothing happens.  It doesn't hang up, it doesn't do anything.  I tried looking at the debug.log file but it only shows the path to the last mame game I played.
  If my question has been answered somewhere else I apologize for the unnecessary post but any help on this issue would be greatly appreciated.  Thanks
Re:mamewah and pc games
« Reply #1 on: June 25, 2003, 06:06:54 pm »
Sounds like you've done everything right...just try putting the 'PC' bit in capitals, let me know if that makes any difference...
Syxx
  • Last login:June 25, 2006, 06:36:25 pm
  • Bling Bling
« Reply #2 on: June 25, 2003, 11:36:00 pm »
im having the same issue, i'v tried a .BAT file also that points to the executable and that does the same as the LNK shortcuts, it brings up the loading screen with in mamewah as if its going to load then it shuts down and goes back to mame, loads nothing and does it very fast. i'v done all the above and i have it in CAPS, any ideas?
stuzza
  • Last login:May 13, 2025, 09:19:19 pm
    • ScreenshotArchive
« Reply #3 on: June 25, 2003, 11:59:10 pm »
I use batch files to launch pc games and other exes in Mamewah and havn't had any trouble.  This works fine for me both in Win98 and WinXP.
Here is the settings I use:
;EMULATOR OPTIONS
Emulator Title = Miscellaneous
Logo Image Filename = C:\top logos\miscellaneous top.jpg
'No Snapshot' Image Filename = C:\MAMEWAH\MAMEWAH-NO SNAP.PNG
Emulator Executable = PC
Default Options =
Extra Options #1 =
Extra Options #2 =
Show DOS Box = 0
Send ROM Path = False
Use Long Filenames = False
Send ROM Extension = True
DAT Filename =
NMS Filename =
CatVer Filename =
ROM Path = c:\misc
ROM Extension = bat
List Generation Method = 0
I have separate batch files for each program I want to load located in the misc directory as defined in the ROM Path statement above.
e.g. Here is a batch file that will launch Mame32.
Mame32.bat
cd\
cd "\emu\Mame32"
Mame32.exe
Hope this helps
« Reply #4 on: June 26, 2003, 04:26:24 am »
Try setting 'Show DOS Box' to 'Yes'?...
Popcorrin
« Reply #5 on: June 27, 2003, 10:58:28 am »
Changing 'pc' to capitals did the trick.  Works great.  Thanks for your help.  By the way, awesome FE.
