Author Topic: ArcadeVGA with a light gun?  (Read 2896 times)
Ghoward
  • Last login:July 09, 2021, 10:45:22 pm
  • Mame rocks!!
« on: June 25, 2003, 09:12:27 am »
Hi,
Does anyone know if Arcade VGA will work with the  Act Labs light gun?
Gary
GamingGreg
  • Last login:August 05, 2018, 06:04:30 pm
Re:ArcadeVGA with a light gun?
« Reply #1 on: July 10, 2003, 03:24:30 pm »
You might have found the answer to this already, but I'm told this will work with the USB VGA version of the gun (not the TV version).  Hope that helps.
Also, If you want two guns, Act-Labs has a dual gun system in the works (probably released end of this year).  Or you can try using Analog+ MAME with DOS, Win98 or WinME.  (see some other threads on this)
StephenH
« Reply #2 on: July 11, 2003, 03:13:55 am »
I have heard that the Act Labs gun requires 31Khz mode, not 15Khz mode, which the ArcadeVGA puts out.
MrSaLTy
  • Last login:August 10, 2025, 05:07:28 pm
  • nabisco reject
« Reply #3 on: July 13, 2003, 10:57:44 pm »
I have a arcade monitor, arcadevga, and an act labs light gun, and yes
it works.  I wouldnt call it sooper accurate but I can't say where that issue
lies.  Some games work flawlessly and other are just ok. This may be a
mame issue for all I know.  Anyhow..... It works pretty good as far
as i'm concerned.
