Author Topic: Vision Pro 19" CGA Shelf Mount Monitor Problem  (Read 1582 times)
Ysr5050
  • Last login:March 18, 2009, 02:35:06 pm
« on: February 02, 2009, 12:50:04 am »
Just purchased the Vision Pro 19" CGA shelf mount monitor to replace the original in a Super Pacman stand up.  The video cable from the board splits into two connectors that plug into the original monitor.  Trying to match up the cables from the new monitor results in a lot of flashing colors and lines.
Any advice/help would be appreciated.
Power Supply Frequency: 47-63Hz
Voltage: 90-264vac
Consumption:Less than 70 watts
Input Video Signal  Red, Green, Blue analog input 50 ohm termination to ground
Level: 0 to 2.4 Vpp
Input Sync Signal  Separate H/V sync input
10k termination to ground
Horizontal Deflection Scanning Frequency: Nominal(15-17.5KHz)
Retrace period: <9.0us
Vertical Deflection  Scanning Frequency: 50-65Hz
Retrace period: <900us
Linearity ± 5%
Picture Size Regulation  Static Regulation: 2%
Dynamic Regulation: 1.5%
Geometric Distortion  2%
Degaussing  Auto at power on
High Voltage  27KV
Environmental Conditions  Operating Temperature: 10~60ºC
Humidity: 10º ~ 90%, no condensation
Dot Pitch  .78mm
Power Connector 3 Ckt Molex Power Connector Plug 19-09-2039 with
male terminal 02-09-2116. Mates with 3 Ckt Molex
Power Connector Receptacle 19-09-1039 and
female terminal 02-09-1119
Signal Connector  6 CKT .156 Header
Viewable Size/Type 19" RGB
Resolution  624 x 200
Approvals  UL, CUL, TUV
