Author Topic: Which CPU better for Mame  (Read 2157 times)
mimic
  • Last login:July 20, 2025, 09:41:28 am
« on: January 30, 2009, 11:27:13 pm »
I've got 2Ghz P4 and 2.6 Ghz P4 Celery, which one would be better for mame machine?
TelcoLou
  • Four score and seven years ago our fathers brought forth on this continent, a new nation
  • Last login:October 14, 2010, 01:28:19 am
  • Playing video games since 1977
Re: Which CPU better for Mame
« Reply #1 on: January 30, 2009, 11:32:09 pm »
I would say the 2ghz P4. Celerons suck for everything.
So a leper walks into a bar and as he gets his beer, a finger falls off. The bartender who is serving him turns and pukes all over the place. The leper, feeling bad, says, "Was it my finger falling off?" The bartender turns to him and says, "No, it's the guy dipping chips into your back."
MrMojoZ
  • Last login:June 25, 2009, 11:34:56 pm
« Reply #2 on: January 31, 2009, 12:44:05 am »
So do low speed P4s.
Blanka
« Reply #3 on: January 31, 2009, 02:32:35 am »
Just throw a hefty game at ik MKIII or so, and write down the FPS numbers. May the fastest win!
scriptfactory
  • Last login:February 18, 2009, 04:31:14 pm
« Reply #4 on: January 31, 2009, 04:46:18 am »
And report back your findings here, s'il vous plait. I'm thinking of buying a 3ghz P4 or a 3.4Ghz Celeron for cheap, cheap to throw in my arcade cab.
mimic
« Reply #5 on: January 31, 2009, 09:22:59 pm »
I would love to do it, except... errr... hmmm... you know... I don't know how  :lame:
KDOG
  • Last login:September 18, 2020, 03:08:26 pm
« Reply #6 on: February 01, 2009, 01:07:05 am »
Really what you need to be asking your self is what games do you want to play. If it is the newer 3d games only the fastest out would barely run them if that at all. If that is the CPU( the celeron) that you have then all you need to do is play you favorites in Mame until you find one that doesn't play right. When that happens roll back the version of Mame to an older release along with you Mame set until it does. I would suggest the ones before a major core change.
Check out the FAQ section and the wiki for more help.
« Last Edit: February 01, 2009, 01:08:55 am by KDOG »
cyapps
  • Last login:January 04, 2011, 02:51:31 pm
« Reply #7 on: February 01, 2009, 02:44:24 am »
Is there some sort of table that list all the mame games processors power required. I figured maybe most older games would be under a certain level and only the newest would be taxing, of course there would be some exceptions on both sides.
TAG
  • Last login:May 23, 2014, 05:52:05 pm
« Reply #8 on: February 02, 2009, 02:16:45 pm »
There's the MAME benchmark database that shows the speed at which various versions of MAME run certain games with particular CPUs.
I may not have gone where I intended to go, but I think I have ended up where I needed to be.
-- Dirk Gently
