Author Topic: Startup controll lag - Mala?  (Read 2661 times)
swamprat96
  • Last login:January 10, 2012, 03:29:46 pm
« on: January 25, 2009, 06:21:27 pm »
Down to the last few minor issues. When Mala starts for the first time I have to move the joystick 2 or 3 times or mash the buttons a couple of times before Mala responds. After this it is fine. If I have a keyboard attached as well the keyboard does not have the issue.
Hardware P4 Pentium 2 ghz 512k ram  LCD 17" monitor
Ipac-2 USB
I'm using tree mode in Mala. I'm thinking it could be an Ipac issue?
loadman
  • Moderator
  • Online Online
  • Last login:Today at 05:49:40 pm
  • MaLa FE developer
    • MaLa
Re: Startup controll lag - Mala?
« Reply #1 on: January 25, 2009, 06:23:39 pm »
Yep, Probably.
Do a search on i-pac in this mala forum.
You will probably find that the default player 1 side is ok (like mine)
