Author Topic: whats the best way to apply side art  (Read 2598 times)
purpleprincess
  • Last login:February 13, 2009, 11:34:10 am
« on: January 25, 2009, 05:31:08 pm »
whats the best way to apply side art? has anybody heard of using soap and water. ive heard something about that. thanks for the advice.
mrclean
    • Guscade
Re: whats the best way to apply side art
« Reply #1 on: January 26, 2009, 10:17:28 pm »
you can apply it various methods personally I use the tape & peel / tear an inch off method. Basically you tape the side art on and then you can make sure it's level / and rip actually tear the backing about 1-2'' and slowly peel it downwards while taking off the tape while your going down. I usually use a ruler / yard stick to flatten it while going down. If you get any air bubbles you can usually squeeze them out with the yard stick.
here is a video:
« Last Edit: January 26, 2009, 10:19:29 pm by mrclean »
2,370,650 Gun.Smoke
Trebeck
  • "The Arcade" - Build #4
« Reply #2 on: January 28, 2009, 10:17:16 pm »
Don't do it in a cold environment. I learned that the hard way...
purpleprincess
« Reply #3 on: February 01, 2009, 11:31:27 am »
for the replies ill keep that in mind
MK3FAN
« Reply #4 on: February 08, 2009, 10:10:38 am »
Trebeck
« Reply #5 on: February 08, 2009, 03:20:50 pm »
thanks for the vid that's awesome.
MK3FAN
« Reply #6 on: February 08, 2009, 09:01:05 pm »
No Problem.
