Author Topic: Food Fight analog settings  (Read 7114 times)
mrclean
    • Guscade
« on: January 24, 2009, 09:07:47 pm »
My food fight analog settings are all whacky can someone post theirs thanks
2,370,650 Gun.Smoke
arzoo
  • Last login:May 31, 2026, 10:56:07 am
  • Robots WILL kill you.
    • LEDBlinky
Re: Food Fight analog settings
« Reply #1 on: January 25, 2009, 10:19:53 am »
I was just playing food fight yesterday (can't get past level 11 - and I hate that broccoli) - I think I'm using mame's default settings with a u360 and it works fine.
Robots will kill you.
Arcade Addiction
Ginsu Victim
  • Last login:Yesterday at 03:12:14 pm
  • Comanche, OK -- USA
« Reply #2 on: January 25, 2009, 11:12:38 am »
I don't recall the problem I had, but I'm using U360s with .127 and the default settings are unplayable ---steaming pile of meadow muffin---.
arzoo
    • LEDBlinky
« Reply #3 on: January 25, 2009, 12:33:43 pm »
I don't recall the problem I had, but I'm using U360s with .127 and the default settings are unplayable ---Cleveland steamer---.
I'm using .119, but that shouldn't make any difference. I'll check my settings and post them back here.
Arcade Addiction
DaveMMR
« Reply #4 on: January 25, 2009, 04:15:53 pm »
I have a problem too where my guy wants to move right whenever I'm not doing anything.  In all fairness, I haven't tweaked the stick (too lazy) but I was going to try expanding the dead-zone.
Ginsu Victim
« Reply #5 on: January 25, 2009, 08:41:51 pm »
Oh yeah, that's what mine was doing. He always wanted to go right.
Ummon
  • Trade Count: (+13)
« Reply #6 on: January 25, 2009, 08:49:38 pm »
....um.....
Yo. Chocolate.
Stephen Hawking
Ummon
« Reply #7 on: January 26, 2009, 03:35:47 am »
I looked into this, wondering if it was a U360 issue, and what I found was: if using newer Mame, I had to make sure the analog map was loaded. If not, it would automatically scroll to the right at the level choice screen, and in-game run right and NOT run left. Older mame exhibits all this behavior regardless of map used. Weird. Kind of a lame game anyway, though.
Yo. Chocolate.
Stephen Hawking
Tafoid
  • Last login:February 12, 2025, 04:47:22 am
  • Emulation Devotee
    • MAMELOAD TNG (Front-End)
« Reply #8 on: January 26, 2009, 10:39:21 am »
As a FYI - the 'moves right' issue is logged at MAME Testers already:
http://www.mametesters.org/mantis/view.php?id=2681
mrclean
    • Guscade
« Reply #9 on: January 26, 2009, 11:54:00 am »
I just need someone to post their analog settings because i hit my "enter" button and some numbers accidentally changed
2,370,650 Gun.Smoke
Ginsu Victim
« Reply #10 on: January 26, 2009, 03:22:20 pm »
Thanks. I guess we should check before we gripe ;D
arzoo
    • LEDBlinky
« Reply #11 on: January 26, 2009, 08:06:15 pm »
Here's my analog settings for Food Fight:
Digital Speed: 10
AutoCenter Speed: 10
Reverse: on
Sensitivity: 100%
Arcade Addiction
Ginsu Victim
« Reply #12 on: January 27, 2009, 08:38:44 pm »
I just played Food Fight without any major control issues. The main character would face right still, but he never tried to move that way. I simply hit F2 and configured the joystick. My problem went away after that.
Ummon
« Reply #13 on: January 28, 2009, 01:49:33 am »
Yeah, I confirm this for older Mame. It seems newer mame sort of auto-reconfigured after having an actual analog input.
Yo. Chocolate.
Stephen Hawking
Ginsu Victim
« Reply #14 on: January 28, 2009, 02:20:23 am »
I should've specified the MAME version.
.127
mrclean
    • Guscade
« Reply #15 on: January 29, 2009, 07:04:51 pm »
ok using MAME 129, I have food fight somewhat working now based off of stock settings in a new version of MAME, but what i don't understand is that toward the end when i get a high score i'm only able to properly pick the letters with the track ball.. if i try to use the joystick it works but i can't really select what letters I want, if that makes any sense. It's got something to do with the analog settings. Maybe my U360 isnt launching the correct map for this game ???
2,370,650 Gun.Smoke
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #16 on: January 29, 2009, 07:52:24 pm »
I'm assuming it's jumping too far?  What settings do you have for mame's deadzone?  Did you remap mame's inputs so it treats the joystick as only analog (and not digital inc/dec)?
Robin
Knowledge is Power
Ummon
« Reply #17 on: January 29, 2009, 08:47:39 pm »
I haven't had any trouble. You just have to hold the stick to the outside of the perimeter and then carefully move it around the 'circle' till you get to your letter, then press the fire button. It's rather confusing, initially, because the boy is auto-firing food the whole time.
Yo. Chocolate.
Stephen Hawking
