Author Topic: cpv2 problem  (Read 1349 times)
redketchup
  • Last login:September 30, 2021, 09:22:45 pm
cpv2 problem
« on: January 22, 2009, 09:35:27 pm »
I have installed CPV2 and follow the instruction to generate the file, but when i try to see the control (dos command C:\CVP2\CPV2.EXE -R=PACMAN) I always get the same error message:
"execution error 13"  type incompatibility
I have the last Mame version running with Windows xp
Do you have any idea what i have done wrong..
thanks Gino
Clones
  • Last login:March 18, 2022, 03:00:10 pm
Re: cpv2 problem
« Reply #1 on: January 26, 2009, 10:26:54 am »
When you used the CPV2 Layout designer, and setting up the buttons, was 'arcade' or 'console' check as an option? I had this problem in trying to set up CPV2 for my PC games. I had the Arcade option checked when it should have checked Console. Possibly vicsa versa for you.
But I am definitely not an expert on the matter. I fixed my type 13 error but can only get the static background to show up and not the correct controls for my PC game.
jozhua
  • Last login:August 16, 2009, 02:03:49 am
Re: cpv2 problem
« Reply #2 on: January 26, 2009, 01:23:14 pm »
Did you install the cpv2 system files? They are on the same page as the cpv2 download.
Dazz
  • Last login:January 11, 2025, 07:43:39 am
  • HyperSpin Team
    • VPUniverse
Re: cpv2 problem
« Reply #3 on: January 26, 2009, 02:46:59 pm »
I know that this isn't the answer to your question, but have you checked out CPWizard?  I think CPV2 is starting to show its age, but CPWizard is a very good alternative.
Clones
Re: cpv2 problem
« Reply #4 on: February 03, 2009, 09:43:24 am »
Were you able to figure anything out?
